dance radio
HI have just bought 07 roomy 3,problem is that Dance Radio switches itself ON when it is switched OFF(no key in ignition),also when key is in ignition and ignition is switched on radio comes on,but when ignition is switched OFF and key removed, and car locked up radio switches itself on after approx 5 minutes,HELP,Thank YOU.
I think this is not supposed to happen. It should switch itself on after ignition, it should switch itself off after an hour since the engine ceased (key not removed from ignition) and it should switch itself off as soon as the key is removed from the ignition.
I think that you must visit a Skoda dealer or a car electrician and ask for help.
Take a look at the Dance Unit Manual for more information.
HI thanks for reply,radio does switch off when ignition key removed and car locked,but after about 5 minutes, it decides to switch itsef back on,(think its lonely) cheers
Maybe but i suggest you to visit a Skoda dealer because i think (almost sure) this is a malfunction.
I'd get it over to an auto electrician or a Skoda dealer - I had something similar on an old car I had, and it turned out to be a combination of a borderline-defective radio and a wiring fault.
