Are these the right pads and discs for my car?
If you have ATE brakes they are probably the right ones.
If you don't then they're probably not.
I can't quite see your calipers from here, do you have a webcam?
Whats the difference between the calipers? Did they randomly fit different systems to different cars or is there some sort of pattern to it?
There are three different types of pads and two types of discs for the front!...Better getting them from eurocarparts.....Pagid or Ate brand!! Do the front calipers have FS-III or FS-II stamped on the outside face??? B)
http://www.eurocarparts.com/brake-disc
They have FS-III printed on them - there seems to be only one set of discs that are 256mm (which i'm pretty sure are the right size) but unsure which pads are the right ones. I'll probably be going for Pagid out of recommendation from a few on here.
