Black headlights?
I want to replace my original headlights to black ones. Just cant find any of them..
i dont want that my car looks like Audi http://www.tuning-in.cz/pictures/560-914-o1-devb.jpg
so those i dont want to buy.. Is there anything else?
split yours open and repaint them
Agree with Flybikeslee :)
as above, split yrs down and paint them
i also put R8 led's in mine when i did it, disconnected now
Here's another thread discussing this... link
BTW, how do u split open the headlights and then put them back together again?
They are a complete pig to split or at least mine were,
Either heat gun and a screwdriver and a pair of gloves because you have to get glue bloody hot to get it to release,
Or you could put them in oven and warm them that way, altho i was abit sacred of melting casing doing it that way.
I would advise getting a spare set of lights and doing them then swopping them over then you can take your time and do them
That sounds like a smart plan, thanks. And what about putting back together? I assume they need to be water tight so how do you do this?
i wanted black ones on mine to but couldnt find any anywhere
have you thought about the fly eye kit in black?
thats what i used in the end and looks ok
Yeah I have had a look at fly eyes, and also at laminex. But for me the painted head light is option numero uno...
Hmm.. well i dont want to use flyeyes or something like that.. problems with authorities and inspection.
So there are no black headlights at all on the markets? just those boring looking "audi" headlights..
Well i need to think about that painting.. sounds pretty crazy for me to put headlights in to oven :D
Dont know how many degrees i should use and how much time to let them be on there..
Edited by Tonza
Just use a heat gun then and heat round where glue is bonding the two bits together,
Well have to try that i think.. but what glue i should use to put this piaces back together? that
it wont leak water inside to the lamp or something like that..
windscreen sealant works a treat
Okay ty! well.. i already sprayed my indicators to black.. but i think i just should buy better ones and
clean those back to original colour.. is there any black indicators around?
i found this: http://www.superskoda.com/octavia-i/headlights/skoda-octavia-01-07-facelift-jdm-black-housing-clear-corner-lamps
But those are model 01-07? My car is maded -98 :doh:
And another stupid question.. what kind of spray i should use? matt black, metallic black or something else? should i paint first the base colour and after that the real colour? should i do something to the lamps before spraying like sweat it with sandpaper?
Edited by Tonza
I've got the black indicators from superskoda to go with my headlights, i used hot water and washing up liquid with some scotching stuff bodyshops use to rub paintwork back, most decent motor factors sell it, think sandpaper will be abit harsh,
I prepped it, then plastic primer, then i used satin black as i wanted shiny black as i didn't want to dull headlights and they matched indicators then,
I used window bond on my foglights when i tinted them on my foglights but once you use that there never going to come apart again, I used some PUR adhesive on my headlights, not sure where you would get that from as we use it at work to stick plastic sill trims etc onto cars at work
So those indicators from superskoda match with my model too? -98.. But thanks for the infos!
Is there no way of getting between the gap and feeding paint into the glue? Because that is how I would do it.
Hmm cant even find black indicators next to headlights :'(
