Handbrake Adjustment
Can anyone advise me how to go about adjusting the handbrake on a Fabia2 level 3 please. Not sure whether this is from underneath the car or from inside. If from the inside, would appreciate knowing what I have to remove to get to the adjuster and how to go about this. All help appreciated. Thank you.
Probably want the rear brakes adjusting rather than just winding up the cable.
How do you adjust the back brakes? My handbrake travels too much also.
Handbrake cable adjuster access by removing storage box at rear of centre console near back seats. You need to jack up rear wheels to ensure that you don't take up so much play in cable that brakes bind. This procedure is similar to early Fabia if you can get Haynes manual for that.
the process between drums and discs on the back is slightly diff.
drums you're best to adjust at brakes.
discs by adjusting cable directly as awfabia says
