Skoda yeti columbus face plate skinz mod
DIY carbon fibre skinz mod using 3M vinyl on my columbus set up.
Next set up:
Retrofitting a maxidot instrument cluster from czech republic.
(mine comes with trip computer only, no multi information cluster, only realtime/average fuel consumption, avg speed, current speed, speed limit warning etc)
Buying ross tech hex-can usb cable.
Multifunction steering wheel.
Bluetooth phone set up.
Reverse camera
Reverse camera
Hi, nice mod!
About the reverce camera.. Where will you be installing it? Will you cut a hole on the rear bumper or inside the rear window?
I'm interested to hear your idea because I'm thinking for the same think!
I should be getting the rear handle type camera which are readily avail for vw touran/tiguan, but im not sure whether it fits skoda yeti though..have not really done any research abt it yet.
You want the camera that screws into the number plate light hole.
On the rear of the car you have a pair of them, the camera takes up a small place on one side of those holes, it still has space for a bulb too.
Is that a VW part?
Is that a VW part?
There are VW OEM parts out there for specific model, Tiguan for rear handle mounted camera, Golf for the emblem camera. As for retro fitting rear camera, there several ways, get a NTSC to RGB converter with a aftermarket rear camera that fits the rear liscense plate light. Kufatec IMA might be the best solution to integrate rear camera with additional video aux in.
The kufatec IMA should be the 2nd solution.
If we have this connecting slot, then we will just need to get the OEM camera with the connector and it will be integrated.
for Trajectory Parking Guide Lines, another box is required and it's not cheap. and not sure if it can be used for Skoda. I'm still on the research stage for that. :)
Now we just need to check if the back of our columbus have that connector. :)
Edited by sony
There may be a small problem with that...
Unless you are prepared to cut a hole in the Yeti boot and then weld the bracketry for the rotating badge.
Would be an easy conversion on any Seat or VW though and a very neat solution.
