Windscreen washer tube size
Can anyone tell me the size of the tubing that runs from the washer bottle pump, where it connects at the pump itself? I have a small leak in the tube and rather than try and replace the whole lot, a small cut out and insert with a couple of joiners should do the trick. But I need the right size. I have no way of measuring the tubes here, so if anyone could help I would be grateful.
James
James
Skoda do a male and female repair kit,(which snap together) is the pipe ribbed or smooth if it is ribbed you can defo get a repair kit, we use it a lot where the washer pipe splits behind the dash, on fabias. dead easy to use just cut the split piece out and fit the kit.Phil.
Perfect, sounds like just the job. It is ribbed, so I will look out for the repair kit. Thanks for the tip.
Here are the part nos for the repair kits 5j0955871a and 5j0955871b. Phil.
