engine fault code
hi all ,today when i was driving the car at about 70 mph suddenly i lost the power so i switched the car off and on and it was back to normal. when i came home i did the scan and found the following [ 17958 P1550 Charge Pressure Deviation intermittent ]what is it and how can i fix this ,any help will be greatly appreciate.thanks
I'm getting the same code and have yet to get to the bottom of what is causing it. My car is also an SLX TDi, a 2000 reg with about 96k on it.
Mine's intermittent, and it's had the issue sinc I bought it in April. It's often fine for motorway driving but give it a particularly steep hill and accelerate and it may drop into limp mode. I've found I can replicate it 100% by booting it over the brow of a hill in 3rd accelerating up to motorway speeds. Spirited driving to high revs/load seems to temporarily improve it but is not a permanent solution (and it's never stopped it limping with the hill brow test).
Investigations so far haven't turned up anything conclusive. I suspect something is up with the turbo control or boost. This could be a solenoid, vacuum piping, boost leak, turbo vanes, control ring or actuator...
Tried swapping out a few things and checking the piping. Only thing found to date was a bad connection between piping and intercooler (not completely off though). That was put right but the limp issues have continued. I have read of two people on forums solving or working around it. One had an intercooler / piping connection issue. The other ran without the EGR solenoid plugged in. I've tried both and no joy.
Edit: Sorry - having to reschedule diagnostics.
Edited by Uriel
Copied from another post of mine
Update on this:
Further diagnosis did reveal a definite sticking VNT issue. Realtime logging of requested boost indicated that it was a bit all over the place but mainly overboosting. Remedy was going to be turbo off and remanufacture or replace - plus I wasn't going to DIY it. Unfortunately the whole 'to do' list was longer (needed thermostat, wheel bearing, brake discs + pads replacing sooner rather than later). Tax was coming up (in the engine size rather than CO2 bracket so nearly double a 2001 car)and I had the offer of a long-term interest free car loan from a family member.
To cut a long story short, I'm no longer a Skoda Octavia owner. PXed for a 2010 Honda Insignt ES at the weekend.
Will copy this info into threads where discussion of the car's limp mode was active to bring a little closure. I guess I'll be a lot more scarce around these parts from now on.
