VRS roll bar on a Combi?
I have an 06 Fabia 1 Estate, and I find it a bit roly-poly at times.
Does anyone know (for sure) whether a rear anti-roll bar such as Jabba's would fit a Fabia Estate?
Any reason why I shouldn't fit one?
RARB would fit....have you tried Koni FSD dampers to firm it up a bit?? (these work with standard springs) B)
As long as it's a Fabia MK1, both Whiteline/Jabba rear ARBs and the Skoda Fabia VRS or Eibach front ARBs will fit.
A RARB will certainly make it less roly-poly.
I have the Jabba bar but it was fitted after lowering my VRS on Eibachs springs/dampers. Not too sure what the effect would be on a non-VRS estate but I think "greater" is a good bet. Hence mentioning uprated front bars if things go too far the other way.
J.
