"One touch " indicator stalk
You know the indicator stalks that click 3 times before auto canceling, is there one available for the Fabia?
I had one in the ST and the the OHs Ibiza has one too so I got quite used too it, and kinda miss it a bit.
Or does anyone know if you retro fit the cruise control does this become available on that stalk?
Oooooor is is programmable via VAGCOM?
Thanks in advance
Niall
The Elegance has both on that stalk.
It's not to do with the stalk its programming in the later central electrics control unit.
Have it on my 56 vrs...
Yeah it was fitted from 05MY
Ive got it on my 54 plate vRS. Think it was put on via vagcom?
My mates 54plate had it. What year is your car? Probably possible to vag com it if as Ross said its got the right bits in
Matt
I've got it on my 06 1.4 16v and my bro 55 vrs has it too.
its on my 04 fabia vrs too along with cruise.....
To add, you can change the number of clicks too. :p
Sent from my Desire HD using Tapatalk
I have it too :-)
My 54 plate has it
As said its a feature from 05MY onwards so 04 plate on, cant be turned on by vagcom if its not the right control unit.
I have it on my 2007 1.4 TDI, I would like to fit it on my 2005 1.4 TDI also.
So what do we need to check for and what procedure is required to install it.
Any help greatly appreciated.
DB.
Mines an April 2004 so I'll get it plugged into VAGCOM and see what can be done :)
If you dont have it then you need a new controller, circa 300quid.
Cheers Tech1e, i think that money will stay in my pocket :D
Mine has it, Here's the P/N of my CC Controller for reference, 6Q0 959 433 E
Thanks Mike thats fantastic :)
Seriously why are there no Rep points on this forum?!
Used to IIRC, but I think mine were so high it crashed the system ;)
Octavia owner here, can this be done on Mk1 Octy's too? Mines a 2004 VRS. Would be rather good if you could just vagcom it on!
No, yours just has a regular flasher relay built into the hazzard switch no control unit.
Balls. Cheers chap!
Edited by Jonneh
AFAIK most VAG models with the same style control stalk as Fabia and Mk1 Octavia can be modified to have the 1 touch 3 blink feature.
The VW part nos. to get this feature are:-
Relay: 000 953 227 A
Loom/Kit: 000 998 229 A
Don't think it is too expensive either.
000 998 229 A is the kit and includes the relay, relay socket with pigtail loom, crimps, a cable tie and instructions.
In theory, you should put the relay socket in the relay plate but as the pigtail is fairly short, it often gets secured behind the dash somewhere.
There are just 5 wires to connect.
