Few of the banana
waiting on parts now, useless compnaies. Was promised my clutch for the weekend....won't be here till tuesday. Trying to send back this rear ARB that i was sent instead of the front...guy saying he doesn't accept returns... :lol: we'll see about that when paypal rule in my favour and i keep the ARB the little prik. Few little bits from TPS to grab too.
  • Replies 180
  • Views 17.6k
  • New rear calipers fitted as the old ones were a bit seized. 2 new rear wheel bearings as there was a bit of a drone. Car machine polished and buffed, polished and waxed for ultimate dubs. awesome day.
  • hi mate was good seeing you at Lymm services last weekend. Car looked good and certainly got me pepped up to sort mine out. Hopefully see you around at some shows this year.
  • hello mate, always good to meet new faces! i'll be at most shows this year so no douby bump into you again!
Pic when we took motor out.
Ecu being sent away tomorrow to check a few codes...
Gearbox finally getting collected for rebuild.
R32 ARB still to turn up
Clutch and flywheel to be here Tuesday.
Will also be ordering a short shifter and some stiffer front Arb bushes.
Bays been cleaned of all oil and rubbish too. Lots done, lots still to do!
1 prik power... painted the engine all black too...more pics tomo...
shafts rubbed down and painted, look a tad fresher now
engine murdered look... painted the lot black!
hoses and bits and bobs going back on
rebuilding the turbo with new washers etc
Ecu out and off to Jabba, started cleaning the bay up too
new mani in place
and one of how it stands.... more soon
nice :giggle: the underside of your front bumper has seen better days. What did you paint the engine with?
bumper aint too bad really, front bit the splitter takes the brunt, and the back bit i gave a coat of black because i didn't like seeing the yellow through the splitter. Painted the engine with satin black. Used it on motors in the past. more than upto the job :thumbup:
Brush or rattle can?
can buddy
Good work Lee again. We still need to catch up soon lad. I have been so busy with the baby though. I've not even had time to fit fmic :/(
ello leigh! that's a valid excuse! :giggle:
got some more stuff bolted up
clutch and flywheel arrived (fly not pictured)
short shifter arrived too...
Just looking into a LSD as it seems the standard one has **** itself.... ooops
engine looking a bit more back together, binned off excess vacuum hoses and other garbage
On the stand for the sump to be dropped and pick up replaced
wasn't too bad but worth replacing
cleaned the sump of excess crap too
Rusty shafts cleaned and painted
black motor
Needs another few coats then its good to go.
Just waiting on an R32 front ARB which will be here by the weekend, and the box should be back this week so can whack the quick shift on that and get that painted black too
Spare bung for my downpipe to so can datalog the car once it's back and rolling.
Basically before the car was taken off the road it was over fuelling slightly. Jabba have checked the map so it's either a sensor or an air leak, the old mani did have a crack in it so maybe that was affecting it. Either way all hoses have been checked and double checked so no vacuum leaks. Fingers crossed once it's back in it won't need logging!
Good work there!
cheers dude, turns out id cracked the gearbox casing too.... the rivets in the dif broke that harshly they cracked it...so have a second hand jobby on there now, box will be back thurs. all built back up on the weekend with clutch and fly, then just wait for the R32 arb, chuck that on and put it all back together...
Any updates?
progress....
g60 flywheel and vr6 clutch
box back and painted by a pro...shortshift also fitted and painted
undersealed the car whilst it was on the ramp, cheeky bit of scrapage there...
chassis legs cleaned up of all the grime
and box bolted back up
literally just waiting on the R32 ARB and we're good to chuck it back in! :)
Next weekends job!
the last piece of the jigsaw arrived! now finding the time to put it back together :giggle:
Very nice!
you know this?
http://www.eurotuning.cz/images/file/conversion_kit.pdf
£900..id rather buy a 6 speed box and a dif :giggle:
Well plenty done lastnight with the boys. Rear polybushed beam and ARB are on! should stiffen things up a treat! snapped a couple of brake pipes but will be putting new ends on those this week and thats good to go.
everythings been treated to a coat of underseal now too.
Engine back in and running in no time at all. Just need a couple of fresh track rod ends and a few odds and sods. It'll be back next weekend fingers crossed getting the clutch run in (probably do a random trip somewhere...)
looking good, what clutch/fly wheel did you go for? Mine has just started slipping so need to replace :doh:
went for the sachs VR6 one, read into them a fair bit and seem to be upto the job. G60 flywheel too :thumbup:
