SOLD - Crabtree 50A Shower Isolator Switch
Crabtree 2167 Ceiling Shower Isolator Switch 50a Double Pole with neon indicator and mechanical indicator.
Terminals accept up to 10mm cable. Pull cord is about 50cm long (this can easily be lengthened if required .
This unit is used as an Isolation switch for an electric shower with a maximum load of 11.5kW. No separate mounting box is required. Plenty of room within unit for 10mm cable. (this is the really thick shower cable)
It is about 5 years old but has only been isolated a handful of times (when on holiday) it was located in the airing cupboard so is in perfect condition visually and it's working condition.
£6.50 posted.
Guest
