Which Oil for my VRS?
Hi everyone.
Done a lil bit of fishing on here but still not sure. Need to top my oil up as is low.
Which oil do i need to get as lots people have opinions but prob stick with VW oils????
I have had it mapped to around 210bhp (Not sure if this makes a difference for what oil i need)
Also was wondering, as im not sure what oil is in it, should i do a oil & oil filter change?
Regards :smirk:
Agree with the above about the oil pump pick up pipe!
We use VW engine oil which really is top notch - no real need to go messing around and chaning it for something else...
But as they say!! Some oil is better than no oil!! :D
Mike
In December it cost me under £29 for oil, oil filter and sump plug from my local skoda dealer. Not sure of the price now with vat @ 20%
I was recommended this: http://www.vwspares....roducts_id=1354 also it might be worth seeing if the oil pump pick up pipe has been replaced.
Do you have part number for Oil Pick Up pipe?
you should use a vw 502 or 504 spec oil
I use 504 spec out of convenience - any brand should do as long as it meets the spec
Think these are the numbers
Vw part numbers:
Oil pick up, 06A 115 251
New o ring, N 028 222 2
