octavia tdi problems
hey there
First thing love the forum am on a coupla cant believe how busy this one is busiest by far
ok so my octy has its faults been readin up on ur site and
my dash has the usuall prob with the clocks failing pulling the 15 fuse worked. thanks to everyone that suggested it i searched for the manual on ebay to repair but failed????????? anyone know it or link to it please thanks
my window doesnt work it will go down but not straight and will go up ass ways too? is it the plastic clips that failed?
also rear window on drivers side won't move it tries to but is stuck thats the whole mechanism right?????
my radio has crap reception if i remove the areil and power thingy behind the radio will the cable work on a standard besting areil?
thanks for ur help
dash - probably a dry joint on a one of the voltage regulators on the dash PCB - have a search, it has been covered a few times. I have a PDF (in german, iirc) which covers the resolution of this - I will see if I can find it, I think it was on my old work laptop.
Windows - probably clips, best bet is to pop the door trim off and have a look.
Radio - do you have an aftermarket HU fitted? If so that is probably the problem. The aerial base has an amplifier in it, which needs powering. This is normally done by the standard Skoda HU, so if this has been replaced you will need a power injector unit, such as this:
http://cgi.ebay.com/Amplified-aerial-adaptor-VAG-VW-AUDI-Seat-cars-PC5-90-/390282865519?pt=LH_DefaultDomain_0&hash=item5adeabeb6f#ht_610wt_794
wow thats great to have that info thanks a million
Sorry that the arrows aren't on the images..... I can try and add them later if you need it, but I think you should be able to figure it out.
cheers mate no need for arrows will update when i take it on
