Rattle from handbrake
Has anyone had any experience of a rattle coming from the handbrake at low speeds. Its annoying the **** out of me but I dont want to lose a full day by taking it to the dealers to find out they cant trace it.
Its a 54 plate fabia vrs with 5.5K onthe clock.
Other than the rattle its a great little car.
theres a little bit of plastic which clips in just under the handbreak itself i had the same probs i just took it off and cliped it bak in again havent had the problem since :rolleyes:
or it could be the passenger seat belt clip rubbing against the centre console, it did this on mine, a small piece of felt stuck on and problem solved.
Des
Hi,
I had this problem with my vRS Octy, mine was the button that rattled, took me months to find what the problem was. I had a new handbrake fitted under warrantee.
If your having trouble take it back to the dealer.
Ta Paul
Thanks for the advice. Will check the items mentioned and if I get no joy I will have to run by the dealer
Hi' date='
[/quote']
:nod: so does mine...
or it could be the passenger seat belt clip rubbing against the centre console' date=' it did this on mine, a small piece of felt stuck on and problem solved.
Des[/quote']
I had this rattle for a couple weeks & now that I've read this post^^^^ the rattle has gone!! :thumbup:
Ditto for me, however the trim was a poor fit and clipping it back in didn't sort it for me, still moved about... gaffa tape to the rescue! (underneath out of view of course, I may drive a skoda but I'm not that much of a pikey :D )
