Boot storage netting
Hello,
I have recently acquired an 06 vrs and the net in the boot has fallen apart. It's the side compartment on the drivers side that has the metal bar across with a net. The bar won't re-attach so I guess I need a new part. Does anyone know which part numbers and whether it is 1 whole part or varios parts? Also I don't know how to take the plastic frame out as I can't see any bolts or any fixings.
Any help is appreciated
Will
I used to work at a dealership and (someone please correct me if I am wrong) I think it's the whole carpet that covers the wheel arch that needs replacing!
This happened on my MKI and I simply drilled out the mounting and bolted it on (both sides) done neatly it will look like it came out the factory like that :thumbup:
Thanks, that's what I was going to do, but thought I'd check as if it was pretty cheap to replace, I'd replace.
Fixed today with a few strategically drilled holes and some cable ties. Looks alright I suppose.
