NEED HELP
where is the hole i can feed the cable through from the engine bay to inside the car??? and where shud i attach power cable to and wheres the best earthing point in the boot?
Edited by robbarr3
remove the glovebox and its behind there i believe its just where the sound deadening stops so far up. If your looking down at the engine bay, the hole is down the back between the pipe that runs from the back of the air box, a clip on either end that you squeeze together and take that off, best way is to poke something through from the car side, then tape the power cable on and then pull back through from the car side (think i had to drill the hole out slightly to get it through, cant remember)
As for the power just attatch to the wire to the positive side, remove the current wiring clip that holds it on, slide the sub wire under and clamp the clip back over and retighten.
As for the earth cable, pull up the boot carpet and find a bit that doesnt have all the black sound deadening on it, sand it back to get metal, put a little pilot hole in, attatch a looped end (not sure the proper term for this electrical end) and then just screw in a self tapper, jobs a good en :)
Elliott
Edited by E11HES
remove the glovebox and its behind there i believe its just where the sound deadening stops so far up. as for the power just attatch to the wire to the positive side, remove the current wiring clip that holds it on, slide the sub wire under and clamp the clip back over and retighten.
Elliott
awesome thanks for that i was gettong lost for a sec lol
