Activate headlight washers?
Hi!
My car has headlight washers, but they do not work or they are not activated? :wonder:
I can see them behind the panel under the headlights.
How can I get them to work?
Obvious observation that you have already probably thought of?
But they only work when headlights are on.
I tried holding the handle backwards to wash the front screen for some time but nothing happens with the headlight washers.
The headlights was switched on. :wonder:
On some VAG models the headlamp washers only work on the 5th activation of the windscreen washer i.e. on the 5th depression of the wiper arm.
Tried splashing 5 times, still no action. :wonder:
How does it work on other Rommies?
If I remember correctly you need to have the headlights on (not only sidelights or DRLs) and splash 5 times. If it still does not work then you probably need to contact your dealer. Coming to think of it - I don't remember seing my headlight washers work either, and the car has soon done 6 000 km, I will need to test tonight...
