Fabia headlights
Can any one help with this one?? I have an X plate Fabia 1.4 16v, when I use the car at night the headlights pulse, dim/bright/dim/bright etc it is only the headlights that are affected the side lights and rear lights are unaffected. There are no other electerical problems and when I put a volt meter across the battery terminals it displays a steady voltage with no fluctuations. The car is dangerous to use at the moment because people think that I am flashing them. Any suggestions???
Could be the negative cable from the battery is faulty......but mainly the PAS and or the two connectors on the wire from the alternator to infront of the lower part of rad. Post this question on the main Fabia section as this is just for the tech guides...not really for questions....you will get a better response!! B)
