Need some help with error codes
I've got three errors on the car can anyone help tell me what they are and how to fix?
0919 - High pressure transducer G65 (i think air con but not sure what?)
0566 - Steering assistance operation
1135 - Vehicle interior motion sensor
Are these just from a generic code reader? Just that on the G65-related error, you should have a bit more info on the type of issue. Least I'd expect that on a VCDS scan.
But yes, a G65 error is air-con related. Could be just related to the level of gas in the system (is AC working properly?) - could be related to the compressor, the wiring to the sensor etc.
Don't recognise the other two errors I'm afraid.
It was generic reader yeah.
Air con doesn't get really cold so I think just a re-gas then.. how much will this cost me roughly?
Straightforward re-gas seems to range from £40-80 depending on where you go. Kwik Fit offer a service for example, not sure if I'd trust them mind you - depends how decent your local branch is really.
On the other issues, a local member with VCDS might shed a bit more light on those. Are you having any issues with steering and the alarm though?
No issues at all.
Cleared them for now to see if they re appear as they could have been old faults ?
But previous owner didn't mention any other issues other than console bush.
Yep, could have been there a while then.
