Fault code 17932 01/01
Just had the cel on and code is 17932 01/01. Something to do with fuel pump relay?. Also the turbo cut out so I'm guessing it's gone into limp mode?. What's causing this as it's the second time in a week it's happened but only this time the cel light is on.?????
Thanks in advance
had the eml on again tonight! vcds came up with the fuel relay again. Simple as replacing it or something more underlying?
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC G000SG 7000
Coding: 00102
Shop #: WSC 13765
1 Fault Found:
17932 - Fuel Pump Relay (J17): Open or Short to Ground
P1524 - 35-00 - -
Readiness: 1 1 0 0 1
Just
Replace
It
Ok
Guest
