How many miles past service due is OK
I have my first variable service coming up in 400 miles.
How many miles can I go "over" this and stay in warranty ?
Would prefer to get it serviced mid November when I will be about 400 miles over.
I think you will be OK
Can't give a definitive answer but I took mine in for its 1st fixed service 400 miles "late" and got a couple of (non-engine related) warranty bits done at the same time.
Shouldn't be too bad, providing you don't go over the maximum allowed mileage (18,000 miles I believe) then you should be OK.
Ian
Ian
Hmmmm, I'm on variable service interval, it says service in 400 miles, I'm already at 18,600 on the odometer !
You obviously do a lot of motorway type miles, perhaps it would be good to check your handbook just to be sure what you can go up to.
Ian.
I think you have 1k. Doesn't say anything in the book about going over. I also got 18.6k out of the interval and took it in just before 19k
I have in the past gone 1500 over the interval because the dealer could not get me in. But I do 1000 a week so it was only a few days overdue.
Most brands dealers will allow upto 1K or 10 days over the mileage or dated services to allow for high milers and full up diaries.
I am always over in the works car, but so long as it's booked and you get there under this you're usually OK as far as warranty goes.
I went 1000 miles over and all was still ok I was assured.
Ian
I though variable had no max, our Mk1 1.9 tdi always managed 23-24000 miles.
Variable servicing does indeed have a maximum mileage, its about 2 years or 19000 miles on the MK1 petrol, and 30K but still 2 years on the diesel MK1. The MK2 is set at 18.6Kish or 2 years regardless of petrol or diesel. The MK2 software works in KMs, so the limit is 30K Kms or 2 years.
Have you checked the warranty document? Not sure what the new car warranty says, but the "approved used" one puts a mile and time limit on how much you can be "over" by (and I can't remember what it is :blush:).
Sensibly surely it should be a %age, 5% or 10% whatever.
I would have thought that even 10% over on milage , but the oil kept topped up was better than a "dead on" service but with the oil never checked or indeed run low.
just a thought & I know the manufacturers like their excuses regarding warrenty works.
My MK2 2.0TDi has made it up to 23K miles between Variable services, I think the maximum is actually closer to 30K miles or 2 years!
My Local dealer has previously quoted a max of 1500 miles in exceptional circumstances, i.e they are extremely busy to fit you in & you do lots of miles per day.
Normal is 1000.
Then something isn't right. T3chie might have an idea what it is.
I thought it was a max of 50000km?
