Boost Gauge Wiring
Hey guys,
Just a quick question, I have a normal mechanical boost gauge and I just wondered if anybody knew which colour wire to tap into off the light switch?
I know the red/black wire is live feed when ignition is switched on, but I want power only when the lights are on, i.e. sidelights onwards.
Don't worry if you don't know for sure as I'll just have to go through each terminal with a multimeter tomorrow
Marc
Hey guys,
When I did my w8 mod, I went for:
10: -ve/ground
14: +12v instrumentation feed (non-dimmed), this has power when sidelights or headlights are one. If you are being really good you might want to stick a small (1A) fuse in there.
hth
Brill, just what I wanted. Thanks mbames
No worries. We are all here to help :-)
Just for reference, if you need to source power on the otherside of the car, you can always tap into the glovebox light cabling.
Used the wires you said and it worked spot on first time :)
Now just gotta set-up the Newsouth Spectrum gauge from changing colours by its own :D
