Dealer VCDS Advice Needed
Hi All - looking for some advice. My dad's Golf is showing an error 009299 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal. And also an error relating to the wiring for the towbar (which it seems they have coded incorrectly). I cleared the DPF error and the light went out.
The car is still under warranty - do dealers take it thick if you show them a VCDS print out? Could they start any trouble because I scanned the car?
anyone?
You can show them, however they can't action anything under warranty off one. We don't use VCDS and any warranty claim needs to be proven and accompanied by our dealer diagnostic machine. A DPF fault maybe a faulty pressure sensor, worth getting it looked at..
Thanks for that - im hoping the light comes on again before they get to the dealer on tuesday
Well the light did come back on and they have now fixed the issue - they didnt like it when I mentioned the error of the incorrectly coded trailer module. Tried to tell me that VCDS was crap and that you shouldnt use it on a warrantied car as it can damage it!!! They could not see the error (apparently) and re did the adaption - dont know if it is actually fixed or not but they say lights work fine on their trailer board. The error I was getting was :
19-CAN Gateway -- Status: Malfunction 0010
69-Trailer -- Status: Not registered 0001
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: BLANKED HW: BLANKED
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: BLANKED
Coding: E9801F06000202000003
Shop #: WSC 00896 210 89791
VCID: 37792FEF3FDD
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Mileage: 40741 km
Time Indication: 0
Date: 2025.14.21
Time: 00:20:12
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: BLANKED
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: BLANKED
Coding: 0100000100000000
Shop #: WSC 00000 000 00000
VCID: 306B14F3DAB3
No fault code found.
This is true, you can damage a car with VCDS - if you are clueless.
Speaking of clueless people, it seems that VW are as clueless as (some) Skoda dealers when it comes to towbar coding :wall:
If you want then you can use VCDS to check the coding is done correctly:
Trailer Hitch Retrofitting for VW Golf 5/6 based Models
Yep, as you've seen you need to tread carefully with dealers and taking them printouts.
It's obviously helpful, but I'd usually say go to the dealer and just advise them you have an idea of what the fault might be, so they can start looking in the right area and hopefully save you and them some fault finding time.
Waving printouts under their nose can often offend :)
I don't know, I kind of enjoy it!
Lets them know they can't fob you off with any old rubbish of an excuse.
As long as you are polite and point out that you have had it diagnosed elsewhere first etc. then you should be OK. Some dealers can actually be reasonably friendly!
VCID: 37792FEF3FDD
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Mileage: 40741 km
Time Indication: 0
Date: 2025.14.21
Time: 00:20:12
VCID: 306B14F3DAB3
Looks like the CAN Gateway needs to be told the trailer module is there in the installation list to me.
Yup, when my relatives had issues with the electronics on their Octavia, the dealership they took it back to acted a bit "put-out" when they were told the list of symptoms and given a list of fault codes, as if it was somehow forbidden to have a fault code scanner. Seems a bit daft to me, as they were polite ("x is happening, this is a list of the codes logged, not sure if it's something to do with y, or if that's a red herring?") - I work in IT and love it when I get a fault report from a user with lots of information, as it makes my job so much easier! I know they have to look for themselves to double-check, but it'd at least give them a clue looking at the list of codes ("ah, I've seen this before, probably x").
Couldnt agree more - as a consumer you have every right to know whats going on with your car - perhaps if they were more trustworthy perhaps this would not be needed, however the reaction when I told them Im a software engineer and reading an event log can not possibly do any harm was priceless
For me, it's not even a trust thing. I got the fault code reader for my car so I could give it an occasional check to make sure everything was happy. If ever anything did go wrong, I'd hopefully find it easier to identify the cause and know if it were something I could fix, or if it were something that was best left to a professional. If that were the case, it would then allow me to give the mechanic a better "fault report", hopefully making their life easier! Maybe it's just the geek in me (DBA) making me think like that ... :)
