fabia vrs headunit
Can i just replace my standard symphony headunit with an aftermarket double din easily?
Is it just a straight swap. . . maby need some surrounds to finish it off??
Seen a real nice jvc touch screen nice and cheap.
cheers.
All you need is a little strip at the top which is only a couple of quid at a Skoda dealers. An aerial amplifier is also a good idea. That's about it. Just need to remember to swap the red and yellow cables over on the stereo loom - usually manufacturers will put bullet connectors there so you can do it easily.
Cheers thanks alot :-)
