VRS Suspension noise?
Morning,
I've noticed a strange creak/tick/crack kind of noise from my front suspension when going over speed bumps.
It's not a knock of thud of any sort, is this likely to be the front arb's wearing out?
Sounds like it's the plastic sleeves on the ARB, which sit under the bushes.
You can remove these plastic sleeves. and run the smaller bushes from the revised bar. The later vRS's had a slightly different ARB, in that they didn't have the plastic sleeves under the bushes.
These are the standard bushes available:
ARB bush for 19mm bar (20mm hole for use with sleeve):
1J0 411 314 P
ARB bush for 19mm bar (17mm hole for use without sleeve):
1J0 411 314 S
