Outsde Temp and Screen Wash not working
My outside temp has stopped working along with the window washers, the wipers come on, the motor wines but no water and the empty light comes on :S ....... (yes the bottle is full)
I can find a fuse for any of these either.
when i bought mine both front and back washers wouldnt squirt water. Front was a loose hose on the passenger side (easier accessed from under the car) Just get someone to pull the washer lever when you under and youll soon see the unattached hose (assuming thats the problem!)
My back one is a blocked jet, just need to soak in solvent and prod it with a pin!!
Have no idea about the outside temp sensor though, sorry!
good luck...
Edited by colly
Sounds like a convenience module breakdown to me. If a pipe had popped off the empty warning light wouldn't be on. Could be linked to the temp sender as both are on the same bit of wiring down in the front left of the car.
is there a fuse for that. convenience module sound exspensive
Ive been reading up on the convenience module does that not control the locking and windows.
I dont understand how the motor can run but no water getting through
Problem found, Mouse under the binnet has chewed part of loom and water pipes FFS
