running amp wiring
Anyone found a good place to run the Live from the battery to boot? before i start pulling the interior apart
preferably i would like to run the RCA cables on the other side to minimize interference
Matt
Matt
Do a search for pictorials, basically through a grommet by the upper right engine bay (passengers side) below the window, remove glove box, then route it down and behind the kick panels to the rear seat and feed them through the seat belt anchor or under seat backs. RCAs on the opposite side, under the seat backs away from the postive. Its actually quite easy the hardest part would be removing the kick panels, you need iron fingers and brute strength :thumbup:
ah fantastic, i thought it was going to be that grommet, i spied it the other day, but didnt inspect further, thanks for your help :)
