TPM Button
The button down my the gear stick that has a wheel with a semi-circle around it, and it says 'SET'. When I press the button, the symbol just comes up the the dashboard. What does it do?
Josh
Look in your manual under Tyre Pressure Monitoring
It sets the system after inflating or replacing tyres.
If you make an adjustment to your tyre pressures press and hold until you hear a "Bong". you have reset the TPM
Hope that helps
