coilover fitting questions
Just picked up some weitec hicon gt coilovers from someone on here. .
not gonna fit till after winter. . but in the meantime gonna get any bits.i may need. . .
Are new top mounts or shorter drop links necessary?. . .or another parts i might need?
Cheers :-)
Top mounts are recommended, the drop links really depends on how low you go. IF you drop too much you'll get your ARB rubbing on the driveshafts.
Well its on -25mm springs atm but still has arch gap of about 30mm so i wanna get that down . Going more for stance than real low. . .coz my wheels sit nice and wide upto the arches :-)
I would advise new top mounts because then you can take the front struts of as a whole and not dismantle them like I did which ruined them. Also you might as well get some shortened drop links, apparently from tas the 96-00 modeo ones do the trick and there £14 for the pair of eBay which I have just done because one of my shortened ones have fallen out so these ones I'm going to put some lock tite on :) and apart from that you will need lots wd-40 or similar :) then get some pics up
Know where i can get new top mounts easily or a part number for em?. . .
N yeah id read the mondeo drop links do the job b4. . .got a link for em on ebay please?. .
Thanks for the info :-)
Good advice here... Also mega jealous about you getting weitecs.... I've been looking for ages!!!!!
Not sure about the top mounts but here's the drop link link aha :)
http://item.mobileweb.ebay.co.uk/viewitem?itemId=370480629826
yeah dropped on em really. . 10mins longer and they would Av bin gone coz someone called second dibs just after i got my name on em :-D
bargain too and only done 4000miles.
