FMIC Kit - Group Buy - £200 Delivered
I wonder if you can put the under tray back on? and i suppose you will need to buy some of them VAG coupling thingys aswell :think:
And the pipping is 63mm?
All the clips are included that join the pipes :) and that's a good question about the undertray?
Huxley?? Lol
I think it should be fine tho doesn't seem to hang that low
  • Replies 482
  • Views 50.5k
  • It shouldn't really make a massive diff will it?
  • If you go on there ebay listing it has a landline number to call. It took a few goes as they are busy but got through in the end!
  • joe_vrs_tdi
    joe_vrs_tdi
    fitted mine on the weekend and i took some photos http://www.briskoda.net/forums/topic/239134-tx-autosport-intercooler-work-now-complete/ take a look. some have had no issues but i had to make some b
In fact looking at the pic the undertray is still on the car
Ok, but the pipe work is 63mm. Isnt that too big for a fabia with standard turbo, meaning less boost pressure?
Its a stonker of a size 63mm
With a massive blower.... Vnt20 hybrid i ran 57mm
It wont be too bad on standard turbo and I do plan to get a pd150h when/if mine goes pop
But doesn't look like its sitting right...looks pushed down.
I maybe interested in this still though.
From memory there will be more than enuf clearance for the undertray
Good man. Your not to far from me mate.
y where bout you from dude
Porthill near Potters wheel pub
How much I a difference will it really make?
Why do they worry about a bigger diameter if that would be the case why not fit smaller piping?
What is the standard piping diameter?
Edited by wilsy7
Forge kit and seat sport kit is 51mm
Oem sizes vary....
Like off the turbo its like 40mm at the 90 degree bend
Then at the egr its 57mm
Magic Black mate, yours?
Oem sizes vary....
No do a google search, loads of pd130 owners sticking 2" pipe work on there standard turbos.
2" is 51mm?
You really need to know whats supplied in that kit as you'll require 2 oem connectors the likes you get from forge
The bigger pipework will increase lag i would have though but it should be okay
For the price of the kit it seems worthwhile however
2" is 51mm?
What connectors are those? I thought the silicone hoses just go over the piping and clamp on?
Huxley can you find out anything regarding the connectors please?
They possibly could at 63mm
The forge kits etc use 2 adaptor flanges
One that connects into the oem bottom metal pipe off the turbo
And another which connects into the top plastic intercooler pipe and allows you to connect fmic piping
Im sure someone will post a link from the forge website about what im talking about as im on my phone
I had no lag when running 60mm piping on a remapped pd130, including larger post turbo hose and uprated SMIC with 60mm inlet & outlet. In fact the old Golf standard SMIC (pre-vw clip system) had 60mm inlet and outlet and for some reason VW put smaller diameter piping (inc. crappy pancake pipe) leading into the intercooler and smaller diameter piping leading from it.
Edited by trebormint
Going to sit this out and see if they contain everything to do the conversion and how easy it is.
If all good i'll spend the extra £27 odd and get one.
Sorry meant 2.5"
I will ask if they can supply better pictures.
it's not the diameter of the pipes which have a major affect on the boost( if anything the velocity is reduced and the losses due to resistance are as well), its the fact that when we take into consideration bernoulli's equation and the friction factor of the bends and material which is going to be increased with the longer lengths of pipe. But these losses may be considered negligible when we take into consideration the increases in density of the cooled air though the larger inter cooler
That's given me a thought. £27 really isn't that much of a saving. Is that really the best they can do when 10 are buying sold at once?
Did you haggle or was this their first reply?
