What cool things can I change with a vag-com?
Getting my cruise control fitted soon and there are a few things that I want or need. Like I need my fob recoding and then I'm going to ask for the single button unlock, the beep when unlocked, lazy boy indicators. Are all these doable? And it won't affect/damage anything will it?
Also what other things can be done?
Thanks Jay :)
Thanks Jay :)
I changed the weight of the steering(increased) so it has a more feel when pushing on.It took about 5 seconds to do.
That's about it really.
You could also turn down the EGR a bit.
If you have access to vds-pro you can get the remote control windows too.
Phil
Yeah I saw that was possible, I'm not sure because I would like slightly more weight to it because it is extremely light but how do you code it to a certain weight? Or are there like certain levels?
Phil
Sorry I'm a newbie :( what is the egr?
And with the windows do I need a different button or do I just hold down the button on my fob? Thanks Jay
Anti hijack
All doors unlock from one click or just drivers
Alarm bleeps on lock and unlock
Comfort flashes on indicators
Heated mirror duration
How many wipes after screenwash
Steering heaviness
The EGR is the Exhaust Gas Reirculation valve.
It recirculates the exhaust gasses into the intake to reduce emmissions... and increased the ammount of black carbon entering the engine!
The remote windows works off the normal remote and you just hold the lock/unlock button down.
Big Jase. Do you know the coding for the wipers?
Phil
Don't get the unlock beeps, Too gay and get really old really quickly!
The lock beep is OK though!
Teardrop wipe is in 09 Central Electrics, Cant remember what channel though, Factory set to 5 on pre 07MY Fabia's
Remote windows cant be ensbled on the fabia iirc
You have to install the updated convenience software module
Phil
Any more info on this? I`v searched a fair amount over the past few months and havent found much on it tbh :'(
Worth noting, Tear wipering, Comfort indicators both can only be changed on certain years. :thumbup:
Yes sure.
You basically need a laptop with a serial port (no USB to serial as MS-DOS doesn't support anything to do with USB), a serial OBD-2 cable and a copy of VDS-Pro burnt onto a disc. All of which I have.
I have succesfully enabled it on my car with 4 electric windows and also on 2 other Ibiza's that are three door.
For reference my CCM is: 6Q0 959 433E and so were the two ibiza's.
It cannot be done with VCDS as it can't directly overwrite to the eeeprom memory in the CCM.
I already have comfort indicators on mine so will check if I can do the tear wipe. Thanks.
Phil
Thanks Jay :)
Anti-hijack, locks the doors automagically after you get to 10mph.
Indicators, maybe change momentary or lane change(?!?) from 3 to 5 blinks.
J.
Cheers for the help guys, if possible do you have the codes or the following things:
Single button unlock
Lazy boy (convenience) indicator 3 clicks
Beep lock
lock doors after 10 mph
Cheers Jay
J.
But if I enable this setting along with the beep to lock code then will it not beep when I get over 10mph? Jay
No it won't.
No it won't.
You seem certain haha, I'll take your word ;) you done any of this yourself?
Disable the warning light and beep that lets you know that your bulbs are LED or HID or out.
Interesting reading - I guess someone has had a play around with VAG-COM on my car, previous to me owning it. I've got the 10mph door lock thing and the 3 flashes lane indicator, I find both useful.
Depends on what year it is as something's are enabled as standard
Ah t'is a '54
Ah t'is a '54
I'm sure someone will corrected if I am wrong but I think it is only the facelift models that have the convenience indicators.
If you can do something to a fabia, you can bet Ross has done it :giggle:
Yes sure.
Phil
Thanks very much for the info :thumbup: If only your were closer, i`d have sorted you some beer tokens to do mine! I`ll have to keep a eye out for the various bits and bobs. :thumbup:
Anyone with the codes?
