VCDS (VAGCOM) Key-Com cable
Ok not any good for me any more so for sale is my old vagcom cable.
this is the old serial connection one ran fine on my 2003 bora and on mates 2001 Vrs octi
Genuine Ross tech cable bought from one of the boys over on UK Mk4s length is about 1.8 mtrs, and runs without needing a license code - code is built into the dongle itself
label shows the following
KEY-COM
Dual-K VAG-COM
Dongle interface
RKC102291 Rev B
www.ross-tech.com
Label on the side shows serial number -heavily worn but can make out most of it - and Rev 2.10
Cable was last used a few months ago through my old carputer to check for error codes on a 52 plate passat tdi, without a problem running 903 version of the software i think
open to sensible offers looking for around £45 posted
Cheers for looking
Paul
So would this work with current VCDS?
worked with the current version when i installed it on the carputer which was 906 iirc everytime i used it i got a message saying a new version was avalible to download but didnt have internet in the car to get it
but will only work up to around 2004-05 cars. full speed canbus is a no go for these
Cable "should" work with latest VCDS but not on the newer cars. I am not sure if you can use this cable with an older acceptable licensed version of vag-com (as opposed to VCDS). The older versions like 409.1 works on all cars up to 2004 ish (and would work with this cable)
The KEY-* range is a "high-tech" interface, so will work fine and license all versions of VCDS right up to the latest, as it contains the licensing information inside the dongle.
PM sent, first dibs! :thumbup::giggle:
Provisionally sold to 2skodaFamily
ok please allow me 2nd dibs if doesnt go.
