Slight run on after turning off the ignition
Hi Folks
I'm sure I've seen something about this before, but haven't been able to find it.
Sometimes when I turn the ignition off there is a fraction of a run on from the engine.
I do have a a couple of other faults to address, but none that I believe would cause this. They are:
Check temp sender - either dodgy connection or duff sender - causing over ready, long diesel heater period and can see temperature reading are well out of whack
Possible failing battery - sometimes, particulalry after having been unused for a few days and cold in the morning there is a flick from the ASR light and the one below (ABS?) just as the engine catches when starting
Smoke, but only when started - think this might be related to temp sender and over fuelling
Any ideas?
Tom
Faulty/Lazy/Sticking stop solenoid?
That's the first thing that springs to mind.
Phil
TDI? Could be your anti-shudder valve not closing quickly enough?
It's easy to visually check the anti-shudder flap. When you shut off the engine it should operate and stay in that position for 3+ seconds.
as above, anti-shudder assembly being slow to operate....
