Strange Indicator Problem
My left indicator stopped working but the hazard lights and the parking light works. Fuses are all okay. Can anyone suggest where to look?
If the parking lights work I guess that means the stalk is ok. If the hazards work then that must suggest the bulbs are ok.
I would blame the relay behind in the hazard switch.
+1
I found I could get mine to work by revving the engine when stationary and so increase the battery volts temporarily.
  • 4 weeks later...
The left indicators started working early morning then later stopped in the day.
Ordered a relay off ebay. Fitted it in and now only the left indicator worked with the hazards switched on
I like to think that I got a dud relay. Any suggestions?
Did you buy a new or used relay off eBay?
They fail quite regularly, so if you bought a used one it may also be faulty.
Sounds like the hazard switch relay (if you didn't replace with a new part) if not then i'd suggest the indicator stalk
Try some spraying some switch cleaner in to the indicator stalk might be some dirt blocking it
  • 2 months later...
The replacement relay was aduff, another one was sent but no luck. It was the indicator stalk
