Cam chain tensioner
Trying to source a cam chain tensioner for my VRs.
Local supplier seems to be looking for about £350.
Anyone know if thisis the correct one (shipped from the US) or anywhere else I can try?
1.8T VRS doesn't have a cam chain it has a belt & you should expect to pay about £250 for supply & fit of cambelt kit which will include the tensioner.
Eurocarparts for an aftermarket kit or Trade Part Specialists for a genuine VAG kit.
It does have a chain linking the 2 cams together as theres only one top pulley the belt runs over.
Oops forgot about that :giggle:
That tensioner serves as the VVT controller for cold starts and yep I'm pretty sure that's an expensive part to replace :(
The one above may do it, youd have to try and cross check parts numbers etc though.
What is actually wrong with the chain tensioner,that it needs replaced?had a Leon cupra at work the other week that had a noisy chain tensioner but it was down to low oil pressure,choked oil pump pick up pipe.
I don't know much but I know they are oil pressure controlled, so the above post may help you at a guess :thumbup:
