Battery charging....
Hi all,
i wish to charge my battery up sometime soon as it seems to be getting a little flat.
If i disconnect the battery to do so will i need to get the throttle body reset? or can i just connect it back up and carry on?
My charger has an output of 3.6amps, could i charge the battery with this without disconnecting the battery?
Thanks for the help,
Shaun.
Ah thats good to know, i've always avoided disconnecting it as i've heard that the throttle body would need reseting.
Last year i used a motorbike trickle charger to charge it (output of 0.6A) and it took about 65 hours to top it up.
I'll give it a crack with my 3.6A charger when i get home.
Thanks for the reply,
Shaun.
Throttle body will self adapt over a few driving cycles.
If you do decide to disconnect the battery, when you reconnect it turn the ignition on, & you'll hear a whistling sound from the throttle body, just wait for it to stop before starting the engine.
In recent years I have never bothered to disconnect the battery when charging (but that was on the GFs old shed of a 1.9D Felicia :rofl: ). I once charged my Octavia and likewise I did not bother to disconnect the battery - who wants to faff about resetting the clock, radio stations, etc!
