Interior Dash Sound
Hi,
Anyone experiencing a loose washer or similar loose fitting in the dashboard area passenger side?
Appreciate any thoughts and quick fixes...or is it a dealership issue at big bucks? Best sound description is akin to a nut ontop of a nervous washing machine?
Sound is intermittant not constant.
fonaspin
Edited by fonaspin
Hi,
fonaspin
Will the sound stop, when you place your hand to glovebox from underneath? I have rattling from there and havent time to check it further.
i sometimes have a rattle which
is a pound coin which i placed on dashboard
for my mrs to put in the trolley
at the supermarket,only to see it slide down
the windscreen into the blackhole behind the dashboard.
john
No No No,
Sorry .....no replies solve my issue but , dont ask me Y, the issue has gone in2 hibernation ( forever I hope ).
H N Year all.
fonaspin
Edited by fonaspin
No No No,
H N Year all.
fonaspin
Hope it stays away for you.
If it doesn't, I believe there are some quite common Passat rattles which come and go. See the links here:
dash creaks
more dash creaks
I found on mine the dash end cap near glovebox was rattling - it is very easy for this not to be fitted correctly in its clip/recess, and it has some rubber fittings to stop rattles which I believe can compress so much over time that they no longer do their jobs.
