Help
I have acquired a second hand Whiteline RARB and all the bushes nuts etc are all present minus the two m10 x 90mm bolts washers and m10 nyloc nuts that replace the OE bolt on the bottom of the rear shock absorber.
Just been on the phone to Whiteline UK HQ to try and buy some and the bloke said your best off going to B&Q or Homebase as the bits are cheaper and I wouldn't have to pay the ridiculous £15 charge for any size order to be
delivered from Fedex, which is a bit steep for some nuts
and bolts that weigh bugger all.
I have been to the above shops and couldn't find anything, even asked some members of staff also.
Anybody else been in my situation and had to buy these as mentioned? Can you provide any links? Thanks in advance. And cheers for reading.
Edited by redcupraboy
Have you got a local screwfix as a pack of 10 M10 90mm bolts is £6.02 and the nuts i think are £3 for 10.
Matt
http://www.screwfix....&priceFilterOn=
I should have some on my van, ill have a look, can't guarantee there 90mm though
Rich
Combatnurse999 cheers for that your a star, just what I'm after, didn't think to try Screwfix. Thanks again.
If you luck out I may have something suitable at work.
Cheers Ross mate, il let you know if I get stuck.
