HID Ballast Locations
Any one got pictures on where they have located the Ballasts for their HID kits, Pref somewhere where they can be just cable tied. Not sure how I use the brackets which were supplied.
Oh I have read that the ballasts need to be grounded to the car chassis via the metal brackets.
Soooo if i wanted to cable tie them somewhere I could just run a 2mm earth Cable from ballast to chassis?
I mounted mine directly behind the headlight covers as per OEM using some small bolts and rubber washers, and a drill. Had to use a dremel to remove some of the plastic, but it was very easy.
Pete
Pete
I did this on the drivers side, and mounted the passenger side to the side of the battery cover.
So they dont have to be mounted to the chassis?
  • 5 weeks later...
No, not that I know of - consider that the OEM ballasts are mounted on the plastic rear headlight covers.
