Alloy wheels
HI all i have been offered some 255/30/19 rs 6 wheels will these fit a 2007 octy VRS thanks
offset, PCD, number of bolts and width would all help us answer the question...
unless anyone on here happens to know the dimensions of the wheels you'd have to do some more research to find the measurements and come back with them... :)
i will go and get one latter and try it on the car. has any one run 255 tyres on an octy mrk2?Just found offset is ET32
Edited by H11nta
they'll bolt on the hub without any problem, but they'll be way too wide and that offset is very low. IIRC the RS6 has 9" wide rims, with that offset you'd be almost 40mm extra poke. Also that tyre size is too big (as in WIDE - high chance of rubbing) plus your rolling radius will be a lot bigger, meaning speedo etc is wrong.
not to worried about the speedo. Are there any spacres i could get i realy want change the standard 17" wheels.
Spacers can't help you! A wide-arch kit might.
If that 40mm figure is correct, I think you're out of luck.
Spacers will make it even worse!
:p
The OE sizes for 18"s on the vRS are 7.5" wide with et51.
:p
Just been told the are 19x8 5x112mm 255/35/19 not sure what et is
Edited by H11nta
I think they will fit! (As long as you trim the wheel arches back and fit a wide body kit like the old Suzi Vitara's) lol
