starting problems
Hi Everyone just signed up. My 06 plate octavia classic 1.9 tdi developed this starting problem about 6 months ago. it has got worse since the weather got colder. i have had it on to different diagnostic machines and nothing has showen up on any. i have changed the fuel filter, temp sensor to no avail. oh and the battery as well!! Once running the car is fine but left over-night it won't start. has anyone got any suggestions thanks
Glow plugs ? -anyone give a suggestion /
i would say one of 2 things,
1 glow plugs
2 thermostat
in order of expenses i'd go for:
1. diesel filter (u've done this one)
2. glow plugs
3. injectors
seen this happen about a month ago since it's gotten colder. went all the way to the injectors (2 faulty).
Edited by za_killer
2. glow plugs
3. injectors
Also check with a voltmeter that you are getting a 12V supply at the glow plugs for the few seconds after switching on (only when the temperature is below about 5C).
The supply is switched by a relay and this can fail.
