dsg oil change
hallo,
does enyone no how you change the dsg oil/filter,i have seen a drain plug and two filter housings,one under hood and one under,is it realy a garage job?i understand it to be a pricey job so can i do it myself.
You need the correct filling equipment and VCDS to set the level.
Oil is drained out the bottom of the box and then filled back up again through the drain bung.
