WOOP just got me a rs estste!
If i remember ill deffo put a thread up. I just hope i get it home in tact as the last owner left the cambelt 6000 miles over due!! :o
in a fight.. hmmmmmm :wonder:
looking forward to see what you do with the estate B)
i look forward to it too mate. Thursday, after i fitted all that up there ^^ i have a Front upper strut brace to fit, braided brake lines, carbon fibre OEM mirrors, 20mm rear spacers, either red or yellow poly or R32 dogbone mount as i have all 3. Pioneer AVH 3200bt, boost gauge. Other than removal, is there any way to shut up that SAI as mines noisy? :thumbup:
Edited by [email protected]
Check the SAI to see if it is pulling apart. Rivets are probably loose in the SAI. Replace with screws and nuts and should quiten it down. :thumbup:
Nice one bowders, i did wonder if that was the case. :thumbup:
No worries, a common fault. Vibrations cause the rivets to pull through the plastic surround then air gets in and causes the loud noise. Closing it back up using screws and nuts fixes it
good, coz i really cant be bothered to remove it... its long! i want to get acquainted before i start ripping its guts off. (i give it a week!) :rofl:
1 more sleep! :giggle:
i took the arm rest out my Bora today.. dont suppose anyone knows if they will bolt right into the RS?
Edited by Gee-man
I think you need a different metal base bracket and different side covers to fit in the VRS properly
