URGENT! Aargh! lost locking wheelnut key
Things going from bad to worse here!
After destroying my scout's engine on friday I wanted to put its snow tyres onto my wife's leon as that's the only car we've got at the moment. She's due to go into labour any day now so need to have the leon as good as poss in this weather. To add to the problems I've got atleast 100 miles to drive tomorrow for work so need to get this sorted today!
Went to swap them last night and found that I've now lost my locking wheelnut key! I always keep it in the ashtray but it's not there...
How can I get the wheels off? Presume I won't be able to drill them as they're hardened steel - TPS and garages aren't open on a sunday. What can be done?
thanks in desperation
a
Are you in skoda assist or rac, etc, they may help ?:thumbup:
Where abouts are you?
What type of lockers do you have? I would assume they are the EVO style (look like mcguard ones).
Probably needs those hammer on, mangle-up, reverse threaded lokcing bolt removal tools. Usually only had by garages. :(
Sounds pretty daft, but best solution is to try and think back to where you left that damned locking key! Looked everywhere? (or did you commit the cardinal sin of leaving it on the key once fitted, and then drove off?....I did that once and the key was still on the bolt *phew)
Sorry to hear about your problem! I have nearly left mine lying on the side of the road once, in fact, you have reminded me that I had planned to paint it fluorescent orange - must do that now. I would guess yes RAC or dealer would have a way around it.
no idea what the name of the bolt type is but it's basically an oversized spline drive. I'm about to head out to the car again (with my wife (can always find things!)) to tear the car apart to find it. If not will find a suitable sized bit of metal to hammer into the head and wrench it out (fingers crossed it's not too seized)
I'm in melton mowbray, so if anyone's got a bit of kit to sort this out there are plenty of beer tokens available!
mine lives in a hole in the plastic "basket" of tools the sits in the centre of spare wheel. have you got anything like that?
On my car there is a specific place in the polystyrene insert that sits in the spare wheel where the locking bolt fits into, is there not one on your car.
On your car's last visit to a garage have they put it there or in the spare wheel well?
car has now been emptied - definitely not in there. (not even in the spare wheel well!) think i might have to get mediaeval in its arse
I once was in the same situation. I got a lock wheel nut removal tool as mention above from halfords. Worked a treat :thumbup: Only about a tenner to!
I had the assistance of an impact driver though so might of made it easier.
If its the spline drive type then head on down to Halfords and try and get a VW gearbox drain plug tool.
Bottom left in that pic. Hammer that in and they come off easy enough.
Where are you in the country?
There may be a member nearby who could lend you theirs? (I'm assuming the spline is a standard pattern?....)
Worth a shot?
Niall
I'm 15 mins away pm me if you can't get it sorted
thanks for all of the replies - been to hellfrauds - apparently have no suitable tool. Giving up today ad will head to TPS tomorrow...
If they can't do it the spline hammered in will be the next choice
;Niall - thanks for that - have tried my wife's leon key and father in law's touran key with no luck 0 theirs are splines but mine's got castellations on it
Replacement from dealer?
Sounds like the standard locking nut rather than an aftermarket McGard type.
Try Skoda Parts - I had same problem with Octavia spline and they sent parts arrived next day.
Otherwise weld a nut to wheel spine bolt to remove.
http://www.skodaparts.com/product/locking-wheel-nuts-21098
AMI
Keep trying different people, found out mine are the same as another members, lest I know who nicked my spiders if they ever go missing lol
These are all the different types and configurations
just so you have an idea.
Thanks all. TPS Leicester saved the day in the end , had the box of bolts as shown above. Luckily I have got spacers on the rear wheels with long bolts so I had a spare locking bolt for comparison
Thanks for all of your help
A
