New owner few questions
Proud owner of a Vrs again! Few questions,1 how to I activate auto lock ?, what is needed for aux port for iPod use and last do all Vrs heating go extremely hot then cool then hot again with out touching the dial, thanks in advanced
Heater Hot/Cold probably needs a new Flap Motor, a very common fault, mine did.
DB
1 Auto lock/anti hijack needs to be enabled through vcds (vagcom)
2 im not 100% sure! Does it have the standard radio? If so, ebay connects2
3 Flap motor. But can try vcds and resetting the flap motor and see what happens
How much for vagcom mate
hot/cold heater could be the heater control panel - it has a temp sensor in it that messes thing up!
Seen some cables on eBay for 20 quid are they any good
They are only limited to what they can do
No they are utter ****e. Waste of money.
