Gearbox off an ASZ Bora.......fit my ASZ?
Just a quick one, I'm gonna replace my Gearbox shortly, but does anyone know whether or not a gearbox off an Bora, which had an ASZ engine would fit my Fabia VRS ASZ?
I'm 99% sure I can, but just want to confirm ratios are fine, and there's no differnece on the cable operation.
Will be fine. :) There are three different ratios out there though depending on age/model, so ideally you want the same three letter gearbox code. Saying that, no bigge if its not the same. I am running an ASZ box from an Ibiza with longer ratio gears fine. :)
No problems.
Try and get an earlier one as they have the longer ratios in. Makes for a nicer drive on the motorway and really helps economy at higher speeds.
6th in the old box is about equivelent to 5th in the newer one.
Here is some info on the different boxes:
http://www.briskoda.net/forums/topic/177793-fabia-vrs-gearbox-changes/
Phil
Pmd
Thanks guys, puts my mind at ease!
I've got a 53 plate, longer ratio one there if you're after one, needs removing though, I was contemplating putting it in mine because I prefered it to the newer one, but don't have the time / money
