Rear Trim Removal
Hi there,
can anyone out there help with (or point to a location) details of how to remove the rear side (black, plastic) trim in the boot, from floor to window base, I need to get down to the metal.
Aby help much appreciated.
Care needs to be taken removing these due to the curtain airbag!
Be careful not to snap off the plastic tangs in the bottom corners as the dealer did with mine or loose some of the other clips; see photo below :doh:
If you have the spare wheel you will need to remove the false floor;
Remove the two vertical fasteners; one either side to release the carpet cover from the boxes;
then remove the fasteners holding the boxes to the floor.
Most of the fixing screws are Torx head but the sizes escape me from memory.
Hope of help,
TP
People like you make forums worthwhile.... :thumbup:
i will second that.information like that is priceless
Does that info come from the erWin site?
Have a copy of the 2011 Skoda elsawin purchased from fleebay.
Also had a few copies of the ETKA parts system but they appear to stop working after a while, something to do with the licence running out I believe.
If you need any particular Yeti diagram then just send me a PM and I'll see if I've got it.
TP
Thanks; I'll never use 99% of the info but I like to know how it's put together.
I tried to download a manual on-line, however haing paaid for the service the manual isn't actually there. Caveat Emptor
I've now ordered a disc from Ebay. It looks similar to the above.
You MUST remove the boot hook rails first, they bolt through into the side of the car. Trying to do anything with that trim panel without first removing them will get you nowhere!
Thanks Speedsport
  • 1 year later...
Hi, just found this topic is exactly what I need - but the pictures are gone? Is there any way to reload them, please, or give some further instructions?
Thanks!
Black Yeti TSI 1.2 petrol
Thanks!
PM TP I'm sure he will oblige and send you the photos
Many many thanks to everybody!!!
Exactly what is needed!
Hello
I need to replace the closing mechanism for the fuel filler cap on my 2010 Yeti. I suspect that to access this I need to remove the side trim as indicated above, however most of the photos in Plumber's post are no longer visible.
Could anyone confirm if I'm going in the right direction re access, and whether they have photos/diagrams or where I might find them?
Many thanks
Philip
Hello Kevin
Thanks for you post and diagrams. As you've probably realised it's the part numbered 5 that I need to replace. I can't though from the diagram work out how I access behind the filler area. I presume that the screw 3 holds the mechanism in place against the back of the filler but loosening it won't get me very far. Ideas?
Regards
Philip
That would be accessed from behind the right trim panel in  the boot,
Boot trim it is then and I've found the excellent guide in the tow bar post.
Thanks again for your help.
Philip
