Fans Running on..........
Get in the car, drive to work, 3 miles, Air Con on, get to work park up turn off engine and the fans ruin for a few seconds then stop. If I do the same journey with the Air Con Off it doesn't do it.
Is it Air Con related or not?
Can't be an interruption of a regen cos the car no longer has a DPF.
Is this normal?
Thanks Andy
Mine does this, fan is loud, but seems perfectly normal.
After a few seconds following engine off, the fan turns off and slows down, sounds like a light aircraft coming in to land.
As said, this appears to be normal.
