Fault code p1250 prc solenoid, fuel pressure or [fuel low]
hey all,
been having countless problems with the fabia,
got her scanned and gave me the following fault code: p1250, prc solenoid fuel pressure, [Fuel Low]
under the following conditions i get these symptoms:
normal steady driving - fine
hard accelerating to get to motorway speeds rpm surges,
continuous hard accelerating in gears ; 2,3,4 up to motorway speeds engine surges and engine check light on,
next time car starts no engine managment line car fine.
with check light on; Idle very rough, and jumpy.
any ideas?
kind regards.
You don't usually see this code on its own. I suspect that your generic code reader is not seeing all the codes or you haven't stepped through all the codes.
Try a new vw fuel filter and clear the codes
ok, ive already changed the fuel filter,how ever ive got a removable regulator and trying to get a new one of them is like rocking horse ****! unless anyone has any ideas where to find one? other wise its a case of resetting the codes, I also had a cylinder 2 misfire before hand but that cleared and gave me this current fault?
