dtc18062
hi my 52 plate 1.9td has a bit of a miss on it at low speeds possible sticky vane on the turbo any ideas welcome thank you
I suggest you do an autoscan and post the results (edit out the VIN). Make sure you download the most recent version. This code rarely appears on its own and often appears with a terminal 30 or sensor fault.
